Discovering Python I am now in front of a weird behavior with a pre render script.
In the python shell when I type this :
import sys
open('D:\\_Houdini\\test.txt', ‘w’)
A new text file his create on the right place.
When I copy/paste it to the pre render param ( via the expression editor)
I got an error
invalid filename “D:\\_Houdini\test.txt”
so I have to write my path like so to make it to work :
open('D:\\_Houdini\\\test.txt', ‘w’)
any explaination for this ?
new script question
3187 6 2- vbk!!!
- 383 posts
- animatrix_
- 4516 posts
Yeah because “\t” is an escape sequence for a tab character:
http://docs.python.org/2/reference/lexical_analysis.html#string-literals [docs.python.org]
- tjeeds
- 339 posts
What is the worst mistake ever made in computer science and programming that proved to be painful for programmers for years?
http://qr.ae/tLHCH [qr.ae]
Jesse Erickson
Fx Animator
WDAS
Fx Animator
WDAS
- vbk!!!
- 383 posts
- animatrix_
- 4516 posts
I think Tony Hoare's null reference is the biggest mistake ever made in CS:
“Speaking at a conference in 2009, Hoare apologized for inventing the null reference:
I call it my billion-dollar mistake. It was the invention of the null reference in 1965. At that time, I was designing the first comprehensive type system for references in an object oriented language (ALGOL W). My goal was to ensure that all use of references should be absolutely safe, with checking performed automatically by the compiler. But I couldn't resist the temptation to put in a null reference, simply because it was so easy to implement. This has led to innumerable errors, vulnerabilities, and system crashes, which have probably caused a billion dollars of pain and damage in the last forty years.”
http://en.wikipedia.org/wiki/Tony_Hoare [en.wikipedia.org]
http://twistedoakstudios.com/blog/Post330_non-nullable-types-vs-c-fixing-the-billion-dollar-mistake [twistedoakstudios.com]
- edward
- 7722 posts
vbk!!!
I think it's because the expression itself will get expanded first, so the backslash before test needs an additional level of escaping. The slash after the D: I would have expected to need escaping as well, maybe it does get stripped to D:_Houdini so that's valid too. The simple thing to do here is to just use the forward slash instead of the back slash. ie. open('D_Houdini/test.txt', ‘w’)
- vbk!!!
- 383 posts
