Rigid Transform from Deformed Geometry
   6563   8   0
Hi all,
Does anyone have a good method for deriving a transform that would represent the best fit of a reference geometry to an arbitrarily transformed geometry (of the same topology)?
Thanks in advance,
Jason
Extract Transform Object does exactly that (considering that the geometries only differ by transform and no other deformation)
CG Supervisor
Framestore, NY
Thanks tamte!
I don't know how I missed that! Now I do wish there was a python function or a SOP version of that; using Objects like this can be rather awkward inside setups, don't you think?
Take care,
Jason
yes, SOP, Python or VEX version would be great as well
for now you can include Scene Network with nested Extract Transform Object inside of your asset and sample transform matrix by python or VEX
should work with COPy/Foreach Stamping as well so you can have just one Extract Transform and feeding different geometry pairs per copy/point/primitive and getting the matrix so using it sort of like a function to precompute matrices and store to points then you can just access them quickly later, or keep it live
but yes, still akward
CG Supervisor
Framestore, NY
Yeah, we've got it working for us, but it's not pretty
Does anyone know the HDK function that does this? I'll try an inlinecpp if I can find it!
looks like this
http://www.sidefx.com/docs/hdk13.0/_o_b_j___extract_geo_8h_source.html [sidefx.com]
CG Supervisor
Framestore, NY
Yeah, I can't tell from that which function it's using to do the work; and I've done a little wading through GU_Detail with no luck so far. It's gotta be in there somewhere!
I've used this for prototyping a tool that would search published geo datasets where the artists “forgot” to leverage instancing.
http://elonen.iki.fi/code/misc-notes/affine-fit/ [elonen.iki.fi]
Comes in handy when a 1,000,000 poly object is actually composed of a much smaller instancible subset of geo that was copy, pasted, and combined in Maya.
Nice resource, thanks!
