How to use nodes to select ring or loop edges?
25583 21 6- Tesla_s_fan
- 129 posts
- Sadjad Rabiee
- 1391 posts
I believe that Houdini is more than a simple 3D software , It is pretty like to programming languages like C++ :shock:
Because you can create every things with Houdini exactly like C++ even your custom tools or library or function doesn't exist !!!
Maybe Houdini doesn't have some many special tools like “Edge Loop SOP” ,But you can simply make your custom tool with Houdini's powerful tools like VEX 8)
I made a very simple “Edge/Point Loop Tool” for you and you can complete this tool with do some changes in it's network :wink:
- sl0throp
- 258 posts
- mzigaib
- 949 posts
- animatrix_
- 4523 posts
mzigaib
Any tips on how to select and edge ring?
If you want a procedural way, you can use this:
https://www.orbolt.com/asset/animatrix::selectEdgeRing::1.00 [orbolt.com]
- PradeepBarua
- 443 posts
- Tesla_s_fan
- 129 posts
- riviera
- 1694 posts
https://www.facebook.com/ [facebook.com]
photo.php?fbid=702591523107968
qLib just got a new SOP for selecting edge loops procedurally, if you feel like it give it a try (this is a first prototype though, be warned)
Imre Tuske
FX Supervisor | Senior FXTD @ Weta FX
qLib -- Houdini asset library
http://qlab.github.io/qLib/ [qlab.github.io]
https://www.facebook.com/qLibHoudini [www.facebook.com]
- grayOlorin
- 1799 posts
- Tesla_s_fan
- 129 posts
rivierathank you
- animatrix_
- 4523 posts
Adding a VEX-based Select Edge Loop SOP to the list:
https://www.orbolt.com/asset/animatrix::selectEdgeLoop::1.00 [orbolt.com]
It uses the new hedge API.
- Tesla_s_fan
- 129 posts
pusatThank you,I look inside the otl, it's too complex to me , totally can not understand. But I see the note “// VEX grammar doesn't support functions that return arrays.” . In fact houdini support the functions that return arrays, like that:
vector rgb_array()
return { {1, 0, 0}, {0, 1, 0}, {0, 0, 1} };
- animatrix_
- 4523 posts
aty84122pusatThank you,I look inside the otl, it's too complex to me, totally can not understand. But I see the note “// VEX grammar doesn't support functions that return arrays.” . In fact houdini support the functions that return arrays, like that:
vector rgb_array()
Thanks a lot, but are you sure? AFAIK it only works if you write it inside the Outer Code section of Inline Code VOP. Using it inside AttribWrangle SOP throws this error:
I would appreciate to know if there is a solution for this.
Edited by - 2014年10月3日 06:52:36
- Tesla_s_fan
- 129 posts
To pusat:
I just see the help document:http://localhost:48626/vex/arrays [localhost]
or:
http://www.sidefx.com/docs/houdini13.0/vex/arrays [sidefx.com]
But I got the same error in wrangle node. Maybe it has bug.
And I test it in vex type otl, it can works.
or:
- animatrix_
- 4523 posts
I submitted it as a bug in April 15 2014:
Wrangle SOPs do not allow functions that return an array
The developers said:
“This is a problem with the current VEX grammar that doesn't allow array functions inside of functions.
It also isn't allowed in the attrib vop, in your file what is happening is the outer-code section is being abused to define a function, something that will crash and burn when you cut & paste that node.”
- Tesla_s_fan
- 129 posts
- animatrix_
- 4523 posts
Np, please submit an RFE for this as well so SESI can put more priority on this
- Tesla_s_fan
- 129 posts
- ali najeh
- grayOlorin
- 1799 posts
