Snippet error
   6063   7   2
hi,
When i set attribute in snippet in PopVop, it gave error message : “Read-only Expression given for Write-only parameter”.
But i CAN set same attribute in Pop Wrangle . I don't know why. Any help?
Snippet Error.hipnc (221.2 KB)
You can do two things:
1. make it temporary variable by type
float foo = 3;
or
2. use bind to export parameter.
Edited by - 2014年12月16日 10:14:49
check attached file:
snippet_error_165.hipnc (228.7 KB)
thank you!
But I'm still puzzled about it. It seemed geometry wrangle is same as geometry vop. Why Wrangle can do and Vop can't do?
still puzzle.hipnc (213.8 KB)
I want to write some data to custom attribute in pop force vex expression.
How to do it ?
write attribute from vexExpression.hipnc (220.7 KB)
Particle nodes cannot modify particle attributes. Particle DOPs can access particle attributes but can't modify them. Instead they affect the particles by varying the parameter values per-particle.
Warning
This node requires that you understand the vex language. It is very easy to write incorrect code using this node.
I highly recommend you to got through documents.
https://www.sidefx.com/docs/houdini13.0/vex/ [sidefx.com]
http://www.sidefx.com/docs/houdini13.0/vex/snippets [sidefx.com]
In fairness to jerry7, I've been using VEX since it was in Alpha, and the Wrangle nodes (specifically their error messages) still are confusing and hard to use IMO.
I got the message on a POP Wrangle node because I hadn't put * in the Attributes to Create. Unfortunately the error message was useless in helping determine that, because it refered to line number 110, except my code ended at line 50
VOPs are IMO the way to go if you're learning, or aren't an expert user who has memorized the myriad gotchas and intricacies of the Snippets.
I do love VEX, but not in Wrangle nodes I respect those who do like and use Wrangle nodes, but it's purely experts only IMO.
Peter B
Peter Bowmar
____________
