How do I import a background image sequence in the camera? for animation reference purposes?
Rotoscoping
8571 8 4-
- camiloman
- 9 posts
- anon_user_37409885
- 4189 posts
- martinkindl83
- 287 posts
- camiloman
- 9 posts
- sl0throp
- 258 posts
- jordibares
- 655 posts
- camiloman
- 9 posts
- Chirimoya
- 30 posts
Hi Camiloman,
Just to add to the discussion, if your image sequence has padding in front of your frame numbers, you can use this expression:
YourImageFilePath.`padzero(5, $F)`.YourFileExtension
In this example I used a padding of 5 digits, but you can use any number that fits your image sequence.
Don't forget to add the ` before and after the expression.
This will work on the Background tab of the Display Options (d key in the viewport) as well as in the Camera Plane qL node.
- camiloman
- 9 posts
