Polysplit newbie questions
10435 32 2-
- Grendizer
- 375 posts
Hi all 8) I have some questions about Polysplit so please check the attached pictures. The documentation about Polysplit seems very incomplete.
1) Before connecting a new edge to a point, I don't see one single new edge in red, but 2 of them. Why?
2) Once I reach the point I want to connect, its surrounding edges get highlighted in blue. If I move a bit the mouse, the left edge turns blue, if I move again, the upper edge gets highlighted, etc. I was just wondering what does mean this blue highlighting?
Perhaps I'm not using this tool properly and that's why, after I connect a new edge to a point, the target point gets multiplied. I get 2 points inside of one where I connected the edge. And if I move one of these points, a hole appear :?
Oh and by the way, how do I weld 2 points?
Gz
Gz
Houdini gamboler
- Grendizer
- 375 posts
- anon_user_37409885
- 4189 posts
- matthias_k
- 483 posts
@RyuKu
…“ how to merge two selected points to center and how to select one point and move it to another so that they will be merged to the last one? …”
Please have a look at the attached file, do you mean something like this?
Dive into the “grid_object1” to see my try.
The “45 46” in the Group fields of the Fuse Sops are the desired Point Numbers.
After the “average_points” Fuse you have to add another Fuse to delete the duplicated point if you don't like it ;-)
- Grendizer
- 375 posts
Thanks a lot RyuKu and Matthias for the insightful conversation 8)
This thread has a lot of topics so let's take them one by one. Let's start by the “red lines” subject.
What Matthias said that clears up but I just want to make sure I understand correctly. That's why I created an image that I post here. My question is inside this image!!
Thanks !
Thanks !
Houdini gamboler
- 4189 posts
- Grendizer
- 375 posts
Thanks MartybNz
It's weird because a few days ago, when I was using polysplit, I kind of remember points got duplicated on the new edge's intersection with the existing geometry. Now I tried again and I don't have this problem. So perhaps I mixed this tool up with another (edge subdivide?) or perhaps I tweaked a setting that got rid of the double points… ? :?
![](/static/djangobb_forum/img/smilies/neutral.png)
Houdini gamboler
- Grendizer
- 375 posts
Hi again ![](/static/djangobb_forum/img/smilies/smile.png)
Second subject in this thread: the “moving” blue line while using Polysplit.
Ryuku, have you understood better what does it mean? I've read your conversation with Matthias and watched the attached pics. But I am still stucked
ops:
To sum up the question : when one uses Polysplit and starts by a point, the point is highlighted but also an edge connecting this point is highlighted. If I move the mouse, another connected edge is Highlighted. Some goes for the “destination” point. Why?
![](/static/djangobb_forum/img/smilies/yikes.png)
Houdini gamboler
- SreckoM
- 379 posts
- Grendizer
- 375 posts
Heya SreckoM thanks for your input. Actually you are answering to my first question about the red lines, which is already resolved. Now I'm talking about the blue lines that marks existing edges. I would need to create a short video showing what I'm talking about.
What app should I use to capture a video?
Houdini gamboler
- SreckoM
- 379 posts
- Grendizer
- 375 posts
Thanks SreckoM I installed CamStudio.
So in the attached video (re-ecndoded to MPEG4), this is what I'm talking about. When using Polysplit, and when hovering above points, one of the surrounding edge turns blue. If I move a bit the mouse, but stay above the point I want to join, another surrounding edge turns blue. I was just wondering what does mean this blue highlighting…
Note : since a few days, I have lags in Houdni, now trying to find where it comes from…
Houdini gamboler
- SreckoM
- 379 posts
- Grendizer
- 375 posts
- 4189 posts
- Grendizer
- 375 posts
Thanks Marty
Call me a bugger but I just want to understand the logic here
so I have yet another question… :
A point is shared between 2 or more edges, is shared between at least 3 primitive faces.
So if the related edge should be highlighted in blue with he hovered point, then at least 2 edges should be highlighted in blue. However, most of the time, only one edge is highlighted along with the point. What gives?
Houdini gamboler
- 4189 posts
To really understand it's all explained in the documents. Press the ‘?’ on the PolySplit node.
Try clicking on a point then clicking on anther point. The Polysplit ‘Split Locations’ will show something like 3v2 3v3. This means Primitive 3, vert 2 and primitive 3 vert 3. Then put down a reverseSop before and see that the location of the points in your geo will be split in the related places where the primitive has now been shifted.
So fundamentally the primitive is first selected, then the vertex. I'm not seeing any weirdness myself so perhaps its also good to understand the way geometry is setup in Houdini, have a look at the ‘Geometry components’ section below:
http://www.sidefx.com/docs/houdini14.0/model/attributes [sidefx.com]
Edit: The misunderstanding I believe is that you don't actually split on a point, but on a vertex. In Houdini vertex are unique to each primitive/polygon. Therefore the edge is unique and the direction is related to the winding order. To see this more clearly, turn on vertex numbers in Display Options. Hope it helps!
- Grendizer
- 375 posts
Hello Marty
Thanks for your time and sorry to bug you over and over again![](/static/djangobb_forum/img/smilies/smile.png)
Yes, this is confusing. In XSI you add edges on edges and points. Houdini's vertex seem to be the same as XSI's samples, and I'm very astonished that Houdini can join a primitive's vertex to another primitive's vertex as vertex are “inside” primitive faces, while points are shared between different faces.
But OK, let's get used to that. However, I read your explanation, the Polysplit documentation and also Matthias screencap, and I'm still confused…
Please check the attached picture which contains my question…
Houdini gamboler
- 4189 posts
- Grendizer
- 375 posts
Thanks Marty I understand better how it works now.
Yet another question: in the picture above, let's say I want to create a new edge starting from the bottom right of primitive 114, and reaching the top right of primitive 115.
As we said before, edges are connected to vertex, not points.
So does it make a difference if the edge starts by:
- Primitive 114, Vertex 2
- Primitive 115, Vertex 3
- Primitive 138, Vertex 1
- Primitive 139, Vertex 0
Houdini gamboler
