Hi all
Is there anything similar to the Dirtmap shader available for Mental Ray that is available for Mantra or able to be built in Vops to be equivalent ?
(http://animus.brinkster.net/index.html) [animus.brinkster.net]
From what I hear the dirtmap shader is often used in industry.
J
Dirtmap
9696 8 4-
- JohnnyBGoode
- 55 posts
- jason_iversen
- 13045 posts
Not sure about the Dirtmap, but you can use (and modify) the Rust and Mold VOPs to some pretty good effect.
- drew
- 121 posts
JohnnyBGoode
Hi all
J
In the houdini world it's referred to as “ambient occlusion”. Check the video tutorials on vislab, I'm pretty sure there is a global illumination example that shows the use of ambient occlusion.
-Drew
- JColdrick
- 4140 posts
I was going to say that can't be right, but yes, in some circles it does appear that's what they use this thing for - fake GI. That's really strange, and a seriously misleading name.
I'm pretty sure “dirtmap” just means what it sounds like, though - a dirt map shader as Jason alluded to, apart from any tricks that it's used for.
J.C.
I'm pretty sure “dirtmap” just means what it sounds like, though - a dirt map shader as Jason alluded to, apart from any tricks that it's used for.Cheers,
J.C.
John Coldrick
- drew
- 121 posts
JColdrick
I was going to say that can't be right, but yes, in some circles it does appear that's what they use this thing for - fake GI. That's really strange, and a seriously misleading name.I'm pretty sure “dirtmap” just means what it sounds like, though - a dirt map shader as Jason alluded to, apart from any tricks that it's used for.
J.C.
Misleading indeed, but the Dirtmap at http://animus.brinkster.net/index.html [animus.brinkster.net] is doing an occlusion calculation which you can see if you download the mental ray shader source. Its also referred to in this article http://www.evermotion.org/tutorials/rendering/xsi_dirtmap/. [evermotion.org] You can use the shader to get the look of things like polished objects where gunk gets stuck in crevices where in effect you have “cleaning occlusion”
-Drew
- JohnnyBGoode
- 55 posts
Sorry, I should have been a bit clearer about the ‘dirtmap’ use.I have used ambient occlusion quite a bit with houdini, what interests me about dirtmap is that as far as i know it is used as a fake-occlusion and also a fake-GI.
It can gather ambient colour from an environment map for one pass and occlusion for another.
As far as i know this is all fake, and is used by industry quite a bit. So i assume it produces much faster results as a shader than using actual ambient occlusion?
Is there anything similar for Houdini?
- craiglhoffman
- 252 posts
- JohnnyBGoode
- 55 posts
oh cool
thanks for clarifying that for me. So as far as i should be concerned the Ambient Occ done through using a GI light shader in houdini will be no slower and no different a technique? (doesnt houdini let you use an environment map anyway?)
I always thought dirtmap as a cheat way to avoid actually using ambient occ - the Evermotion link that Drew supplied suggests this too.
I just assumed it because I thought it odd to be using a shader to generate ambient occlusion rather than a lighting technique like in Houdini?
J
J
- Simon
- 2199 posts
- オンライン
You might want to look at this thread over at odforce
http://odforce.net/forum/index.php?showtopic=2876 [odforce.net]
It deals with the idea of fast ambient occlussion.
