H15 toon shader
   4947   3   1
I am trying to test out the toon shader in H15. The toon colour shader works fine, but I can't seem to get the toon outline shader to produce anything except solid shapes.
Any suggestions?
test_toon.hipnc (322.9 KB)
Patrick
There should be two duplicated objects (or instance). One with color shader ,another with contour shader.
Thanks! I got it now. I merged the outputs from the two material nodes, and it works fine.
I note that the order in the merge node has no effect.
Patrick
Where do you get the toon assets from? I have been looking everywhere but I cant find it. I downloaded the link above but I can't transfer the shop: toon shader and outline shaded onto my desktop. what do I have to do and Is there a different way to get the assets and definitions?
