ah yes thanks!
apologies i missed that part of the snippet page
@opinput1_P access to individual componenets
17307 28 2- megasets
- 85 posts
- animatrix_
- 4523 posts
getattribute VEX function also doesn't allow integers for input parameter but rather string only which is also pretty limiting, given it's a useful function.
- bonsak
- 459 posts
keyframeHi
@y = v@opinput1_P.y works.
If i enter this in an Attribute Wrangle it doesn't produce any errors but doesn't return any values other than 0.0 either. Regardless of input geo.
-b
- jlait
- 6219 posts
getattribute() is supposed to be replaced by getattrib(). Is there some what in which getattrib() is not working for you? getattrib() is new in 15.0 specifically to hopefully end the reign of getattribute().
I just tried
@y = v@opinput1_P.y;
and it works in 15.0.346 with a default file sop. Do you have the second input wired on the attribute wrangle?
I just tried
- bonsak
- 459 posts
- jlait
- 6219 posts
- animatrix_
- 4523 posts
jlait
Thanks Jeff, getattrib seems to do what I need exactly. I am wondering if it can be used with setattrib to modify, float, int attributes whether it's a single value, vector, or an array of any size?
I just tried reading them using getattrib and it seems to return the values correctly so I assume it should work. Just wanted to hear your take on it.
I will update my tools in this case where some of them are still stuck in PointWrangle because of getattribute/setattribute.
- bonsak
- 459 posts
- jlait
- 6219 posts
pusat
The intent is very much to allow you to finally move out of the old SOP context into all CVEX. So please let us know if there is still some behaviour blocking it….
