Sometimes I hear things like “and then you convert the particles to curve”.
I guess something like this:
https://vimeo.com/150801467 [vimeo.com]
So, what do I need to convert particles to curves?
Just a Convert in the location_particles node?
Or maybe a trail?
What I'm doing right now is a trail, then convert, then a polywire, but I guess if I use a polywire then I don't need a convert?
Curves from particles?
11643 4 1-
- verysame
- 59 posts
- mestela
- 1850 posts
Add sop!
If you have an attribute that is unique for each curve you want to make, you can use an add sop in polygon mode, and tell it to group by that attribute.
Eg, here's a pig, i've scattered points on it, and i'm emitting particles from those points at the default rate, and added some noise and drag.
Look at the geometry spreadsheet, you can see there's a sourceptnum attribute. This is unique for each emission point, so its a good candidate for growing curves.
Append an add sop, switch to polygons mode, by group, add ‘by attribute’, and use ‘sourceptnum’ as the attribute. Instant silly string.
- Pmiller001
- 30 posts
- mestela
- 1850 posts
- Pmiller001
- 30 posts
