attributecreate and delete SOP
2928
3
1
jerry7
2016年2月21日 2:37
HI jim, You have not created Local Variable for claster attribute. You can either enable “Local Variable” option in attribcreate1 node or use @cluster in delete1 node.
2016年2月21日 10:29
Thanks. I tried checking that box before, but I think I used the default all UPPER CASE designation for the variable name. I was watching a tutorial and they didn't check that box, so it threw me off.
grayOlorin
2016年2月21日 21:27
in older tutorials, this would be the case, but it has changed in Houdini 15 (in favor of using the more direct @ syntax when possible)
-G
