Attrib Weight of PolyReduce doesn't have any effect?
3069
4
1
rvb3n
2016年4月21日 11:45
Hi, I'm trying to use PolyReduce to make some mesh lighter. I've painted some weight value for the PolyReduce but the Attrib Weight doesn't seem to have any effects: can you tell me what am I doing wrong?
PolyReduce_test.hipnc (73.4 KB)
tamte
2016年4月21日 12:58
according to tooltip, your attribute has to be called weight not Pw
Tomas Slancik CG Supervisor Framestore, NY
rvb3n
2016年4月21日 13:02
Hi, thank you for your answer! I tried again but I don't see any difference..
PolyReduce_Test02.hipnc (62.1 KB)
tamte
2016年4月22日 9:28
it seems that it doesn't do anything for completely flat plane so just added tiny bit of mountain to break the planarity then you can see the effect I pronounced the weight value differences as well to make it more obvious
polyreduce_test02_fix.hipnc (73.5 KB)
rvb3n
2016年4月22日 9:49
That's awesome Tomas! Thanks a lot! I tried also with a different geometry but I wasn't seeing any difference probably because I was missing also the Attribute Wrangle that you added! Thank you for the help!
