Hey guys,
I have a HDA that I made for Maya with a built in output ROP. Its a particle emitter and it works fine when I key the emission on and off in the Maya view port but when I save to disc it ignores the keyframes and keeps going. To be more specific if I am on a frame with no particles it writes out blank files and when I am on a frame with particles when hitting the cache button it writes out the sequence of emitting points but does not stop.
I get the same problem with a bgeo rop and an alembic rop. It seems like a Sync Asset problem to me.
I am using houdini 15.5 and Maya 2016 extention 2 SP5.
Zybrand
ROPs ignoring keyframes
3790 2 2-
- Zybrand
- 93 posts
- awong
- 818 posts
This is happening because when the output ROP is running, the Maya frame is not actually changing. When the output ROP is running, the Houdini world only gets a single frame snapshot of the Maya world. So from Houdini's point of view, it looks like the emission is not actually changing.
It's possible to workaround this with a bit of work. Instead of letting output ROP run for the entire frame range, the idea is to do one frame at a time. You'd need a script on the Maya side that steps through the Maya frame one at a time. And on each Maya frame, run the ROP for that one frame. This way, the Maya state would be reflected inside Houdini for each frame.
Andrew / アンドリュー
- Zybrand
- 93 posts
