I'm experimenting with booleans in Houdini 16, I am trying with the simple scene I show in the image. I set the boolean to “solid” and “union”, output A-B seams edge group, everything fine. Now I'm trying to create a fillet between the two meshes using polybevel, but it seems that offset parameter doesn't work, it just extends the fillet a bit and then stops, the maximum extension is the one in the image.
What am I doing wrong ?
Thank you
Ray
Houdini 16, booleans and polybevel
35601 92 10- madrenderman
- 129 posts
- NNois
- 174 posts
- Simon van de Lagemaat2
- 116 posts
- madrenderman
- 129 posts
- bardia
- 210 posts
You cannot expect to bevel beyond the ring of polygons incident to edges being bevelled. PolyBevel doesn't check for passing beyond those but it does check for internal collapses that are often related to those limits. With the number of columns on your tubes there's very little room left for bevelling. This is not even a Houdini limitation, no tool out there bevels beyond the immediate ring of polygons. Doing that would easily as difficult of the boolean if not harder. Your old PolyBevel result should also be broken if you inspect it over the top of the lower tube in the picture. You should find some inverted faces there.
- Alexey Vanzhula
- 538 posts
- madrenderman
- 129 posts
- Alexey Vanzhula
- 538 posts
- Alexey Vanzhula
- 538 posts
- madrenderman
- 129 posts
- Alexey Vanzhula
- 538 posts
- nicoM
- 74 posts
Hi Ray,
On orbolt there is a free tool called “mesh blend” it looks similar to the fusion hda from vux.
mesh blend [orbolt.com]
Edited by nicoM - 2017年3月25日 09:57:49
- Alexey Vanzhula
- 538 posts
- nicoM
- 74 posts
- madrenderman
- 129 posts
Thank you nicoM, someone already posted it on discord but I found it a bit complicated. I'll try to use it again
Here is the post they sent me about the hda
http://forums.odforce.net/topic/22265-mesh-blend/#comment-164707 [forums.odforce.net]
- Alexey Vanzhula
- 538 posts
- Alexey Vanzhula
- 538 posts
- nicoM
- 74 posts
- Alexey Vanzhula
- 538 posts
- anon_user_37409885
- 4189 posts
bardia
This is a bit of strange thing to write tbh - other programmers have said you can't make a boolean that you did write in Houdini. Surely you need to do more R&D to try to overcome the limitation instead of saying your expectations are too high.
