Duplicate / Copy and transform
3089 1 1- merkvilson
- 3 posts
- neil_math_comp
- 1743 posts
It looks like there's no difference, apart from what you'd type to get them using the keyboard.
In earlier versions, there was a separate Duplicate node, and it behaved in a way that was subtly, sometimes problematically, different from the old Copy node. For example, in old Duplicate SOP, if you set the number of copies to 4, there would be 5 total copies of the geometry, the original one and 4 more, but the old Copy SOP with the number of copies set to 4 would yield 4 total copies of the geometry, as most people expected. Now, people can still type Tab > “du” > Enter to get a node that copies geometry, but it's now consistent with the Copy and Transform node… because it is the Copy and Transform node.
