You should send it in as a bug - the HDA isn't setup to take ad hoc frame numbers, it's set to use the timebar in/out points. The only issue is you are using an inc. of 71. Not sure that would work anyways
Also not sure but you are rendering the wrong geo. That looks like the density that is used to feed the simulation.
Edited by anon_user_37409885 - 2017年6月15日 01:15:47
Thank you, i tried all possible nodes i could. maybe is a bug, the flip book indeed work, looks like houdini want me to make all the simulation until that frame, but as i selected frame 71 and only one frame, he stop the simulation at frame 1
