copy geometry by an exact amount
   3439   2   0
I have some geometry i'm trying to copy (shown image 0)
but when i copy it to points that are distributed by a certain distance the vertices don't meet properly(see image1)
I used the measure sop to define a distance (shown image 2)
I then used the resample node to specify the distance between each point on the curve(image 3)
but unfortunately the vertices do not touch. Is there a way to feed the measure attribute length back to the resample node. Or is the number too long that houdini just won't copy it exactly.
you can use prim() expression in your resample length parm to get the value of length attribue
since Spreadsheet is rounding the numbers so if you manually copy from there, you are not getting the correct value
CG Supervisor
Framestore, NY
Thanks Tomas,that worked !
