I'm trying to figure out how to set the autodopnetwork to a simulation end time
For example, lets say I have 240 frames and I want the particle simulation to spray for 150 frames then end.
How can one accomplish this?
AutodopNetwork End time
4911 6 0- vertigo262
- 55 posts
- Nima
- 471 posts
- vertigo262
- 55 posts
The Autodop is a little nontraditional as it doesn't go by frames, it seems to go by time scales. But I am not trying to prolong the start frame. I want the end frame to end earlier on a specific frame
I am assuming changing the start frame changes when it starts, but not when it finishes
Example timeline of 1 - 240 start on 1, and end on 150
So I don't understand why there is no end frame option
Attachment Not Found
Edited by vertigo262 - 2017年11月14日 05:58:48
- Nima
- 471 posts
Sorry, I thought you wanted to start from specific frame!
There isn't option for end frame because it does't make sense!
You should specify how Houdini ends your simulation.
You can import your sim in a geometry node and then use a Time Shift node to end your imported sim on whatever frame you want.
Another way is to disable sources with a keyframe on specific frame.(if you have particle emission or FLIP or pyro sources for instance)
Edited by Nima - 2017年11月14日 06:36:58
- vertigo262
- 55 posts
This is my Autodop, I have a flip solver if that is what you are refering to
I don't think saving it as a sim will work. Because I want the particles to fall off, after the emitter stops spraying
Example, lets say you turn on a faucet. Then you turn it off. The water still falls to the bottom, but it is no longer coming out the faucet
or maybe that is the velocity setting. I am not sure
Edited by vertigo262 - 2017年11月14日 06:54:40
- Nima
- 471 posts
- vertigo262
- 55 posts
