This is plaguing me. I've created a super-simple scene to illustrate: just a particle emitter with the constant shader attached, and a camera.
Rendered with just depth of field enabled:
Rendered with just motion blur:
But with both, everything goes splotchy:
Doesn't seem to be related to Pixel Samples, or Geo Time Samples. How do I cure it?
What causes these bokeh artifacts and how do I cure them? Should this be RFE'd?
2770 3 1- howiem
- 146 posts
- howiem
- 146 posts
- 7814 posts
Try adding the render property vm_decorrelatedof “Decorrelate Depth of Field from Motion Blur Samples”
It might require even more samples to be smooth, but should help eliminate correlation artifacts (odd boxy noise/missing areas)
Dof requires many times as many samples as a fully opaque render, because of the probabilistic nature of raytracing. When a small point is blurred out into a large disc, the probability of a ray hitting a given particle is reduced by the ratio of the areas. So a particle that when blurred is 10x larger is going to take 100x as many samples to resolve.
- howiem
- 146 posts
Thank you! That's sorted it! Even at 5x5 Pixel samples, as per previous images, that's sooooo much better.
I can up the sampling a bit more, but even with this level of noise, my de-noising plugin can tidy it up - something it couldn't do with the blotchy artifacts from before.
Yay
So - I wonder - under what circumstances does the correlated samples thingy actually benefit you?
Yay
Edited by howiem - 2018年1月21日 05:45:13
