Hello everyone, I need some help here.
As you can see in the picture, one line started at frame 40 (@sFrame=40) and the other one started af frame 42 (@sFrame=42).
I want to pass them inside the dopnet exactly at that frame, so I use one expression on “Impulse Activation”: something like $$FF=@sFrame. I tried many combination but could not make it work.
Can somebody help with that?
Thanks in advance.
Introduce geo into DOPNET at different frames (dopnet impulse activation with an expression?)
1549 2 1- Dav_Rod
- 40 posts
- Dav_Rod
- 40 posts
Trying to explain it better:
1st line is generated af frame 40
2nd line is generated at frame 42
I want to introduce them into the POPsource at each corresponfing frame: 40 and 42.
I was trying some expression that gives a True 1 result on frame 40 and 42. (Something like $$FF=@sFrame)
BUT it seems that the dopnet only read the attributes an the first frame. So I was trying to get the attribute value @sFrame outside of the DOPNetwork with some expression like this: ($F==point(“/obj/SIM/OUT_dynamicCurves_DAV/, ”sFrame", 0))
Can somebody help me to understand how could I do it?
How can I introduce into the DOPNetwork two geos that are born at different frames?
Thanks.
Thanks.
Edited by Dav_Rod - 2018年11月4日 16:48:51
- Andr
- 900 posts
