I'm having problems with promoting parameters/inputs from a custom VOP node. So far I haven't been able to find any info on what is needed for the default mechanism(middle click ->Promote parameter) in houdini to work.
To be more specific I have a shop network where only my custom VOP nodes are allowed plus the houdini's “Parameter” VOP. I would like to be able to promote the parameters/inputs from any VOP inside as parameter to the parent shop node as you can do when using material builder, but can't get my head around this. So far my attempts are failing - houdini is crashing with log attached below.
Thanks.
22705 3 1- millag
- 14 posts
- Enivob
- 2539 posts
- millag
- 14 posts
- DougRichardson
- 29 posts
millag
I don't have this menu next to parameters.
As of Houdini 17 the gear is to the right of each parameter.
From Deborah Fowler's Houdini Interface Tips [www.deborahrfowler.com], I also found out you can MMB on a VOP node to promote a parameter.
