unable to load otl digital assets created in old version Houdini in new version of Houdini
3753
4
0
oat
2019年5月17日 3:37
I'm unable to load the digital assets in otl files created in early version of Houdini (v15) in the latest Houdini (v17). (images attached)
May I ask if I have missed any import steps to load digital assets? (haven't used Houdini for quite a while…)
Thanks.
Edited by oat - 2019年5月17日 03:44:54
Image 1.png (57.8 KB)
Image 2.png (16.3 KB)
Image 4.png (30.8 KB)
jsmack
2019年5月17日 12:25
Do the assets show up in the Asset Library dialog? Are you sure they are Object level assets?
oat
2019年5月21日 1:55
Dear jsmack, thanks for the reply.
The digital assets did show in the asset library dialog when I load them. (see image below)
And, it also shows up in the “asset manager” window.
However, I'm unable to access it by hit the Tab key.
Has the latest Houdini changed the way to load digital asset otl files?
Or, is the latest Houdini not compatible with otls created in older version?
Edited by oat - 2019年5月21日 01:57:32
Image 26.png (55.9 KB)
Image 27.png (51.3 KB)
jsmack
2019年5月23日 2:18
Old assets should load into in new versions fine. Perhaps there is something wrong with the assets' toolscript. Are you able to create the nodes using python? If you inspect an asset's type properties, is the tool script present, and does it look correct? It's hard to guess what could be wrong without investigating myself. Perhaps SideFX support can assist you if you send them an asset to test.
goldfarb
2019年5月23日 11:49
from the above images it looks like you're still in OBJ - but your HDA contains SOPs
Michael Goldfarb |
www.odforce.net Training Lead
www.sidefx.com
