At H17.5, the Atmosphere node was deleted, it is no longer available. What is a reasonable way to create an atmosphere or fog in Houdini?
I want to approach the creation of such a shader, but I do not quite understand how this is possible at the moment. Does anyone have any thoughts on this?
https://ebruneton.github.io/precomputed_atmospheric_scattering/ [ebruneton.github.io]
https://github.com/Scrawk/Brunetons-Improved-Atmospheric-Scattering [github.com]
https://www.youtube.com/watch?v=yCKhQFHybLc [www.youtube.com]
Precompture Atmosphere Scattering
1618 2 2- alexwheezy
- 209 posts
- 7814 posts
There is no reasonable way to do atmosphere in Mantra.
The Atmosphere object can still be used.
A fog shader can be assigned to the pbr engine with the render property
I don't consider either of these methods reasonable, but they allow a low level entry point to the shading engine to implement a custom atmosphere solution.
A regular houdini volume can be used for simple ‘lit fog’ type effects, however they are a poor replacement for the optimized solutions you have linked.
opunhide Object fog
vm_pbrshader
. Doing so requires you to handle all shading for regular objects such as by calling the pbrlighting shader.I don't consider either of these methods reasonable, but they allow a low level entry point to the shading engine to implement a custom atmosphere solution.
- adrianmeyerart
- 36 posts
