Translating a bounding box procedurally, aligning top to 0,0
   4697   3   1
Sorry for the silly question but I'm stuck. It's hard to describe what I want to do with words so I'm attaching an annotated screenshot.
Basically, I need to translate procedurally the wire in the picture so that the top point (A) is always at 0,0. The closest I could get is using the expressions you can also see in the picture. Y alignment works but X alignment is offset because if use bbox D_XMIN the “left-most” point (B) is not on top but around the middle of the wire. Hope this makes sense. Thanks!
オンライン
you can for example subtract position of a point which you want to move to 0
stabilize_by_point.hip (116.5 KB)
CG Supervisor
Framestore, NY
オンライン
Sort node: Point sort by Y, reverse point sort.
Transform node:
Translate X: -point(0, 0, ‘P’, 0)
Translate Y: -point(0, 0, ‘P’, 1)
Translate Z: -point(0, 0, ‘P’, 2)
translate_to_top_point.hipnc (115.8 KB)
Thanks for your inputs. I ended up doing a variation of the sort + transform suggestion. It now works.
