Extrude primitives then flatten the top
   1706   6   0
Hi to all,
I'm struggling with a first Houdini project. I have an irregular ground and need to extrude some faces to produce blocks of specific heights (attribute). But I need to flatten the faces that I extruded. I hope this screencopies will help you understand my meaning.
The terrain :
What I want to do with all the primitives :
So far, I end up with this to flatten the top :
vector P = point(0, "P", 0);
float PY = P.y;
@P.y = PY;
But then I don't really know how to bring back the face to the right Y position.
I'm sure there are better ways to do it. Any idea ?
Thanks !
Nikos Priniotakis
Heritage, visualisation and 3D modeling
Cergy Paris University
not sure if you want to flatten them INDIVIDUALLY or as a whole group.
for as a whole group, in Point SOP, I did the ‘Flatten Bottom’ preset. Just adapt to flatten top instead…(apply this preset to a torus so you get to see the effect first)
something like this:
set(self.x, min(self.y, ch('level') + getbbox_max(0).y), self.z)
Thanks a lot, Vusta ! Neat expression !
In order to do it individually, is the for-each primitive the solution ?
Nikos Priniotakis
here you are…magic…
vu_FlattenPrims.hiplc (125.9 KB)
You're genius !! Thank you so much !! Problem solved
Nikos Priniotakis
This worked great for me flattening the tops of OSM buildings, i projected the data onto my heightfield and needed to straighten the roofs, @Vusta's example worked fantastic, thanks for sharing your knowledge!
This was suuuuper helpful, thanks. I am not a programmer though and was wondering how I would do the same operation for the other axis' like for each side of a box? The code in the file provided works only for top and bottom. Thanks in advance!
Specifically, its this:
set(self.x,lerp(self,@opinput1_P,ch('amount')).y,self.z)
Im not sure how to make this work for other axis. I was hoping it was as easy as swapping the xyz location but its not, lol
edited: nvm I figured it out it was as easy as swapping
set(lerp(self,@opinput1_P,ch('amount')).x,self.y,self.z)
and
Edited by Thunderflex - 2023年5月3日 21:46:06
