Node dependencies in Python
   5965   5   2
Hey guys,
I need to find a way to retrieve the nodes that are referenced by the entire hierarchy used to cook a given node.
With node.references, node.inputAncestors, etc. I think I can get something, but Houdini has a visual representation of this already :
And this is exactly what I need. I want to know which nodes at the same level of the node selected are needed for the selected node.
Is there a function I don't know of that already does this ?
Thanks a lot,
Julien
Screenshot 2020-08-06 at 09.34.53.png (49.2 KB)
VFX Supervisor @ MPC London
Probably the hou.Node.dependents() function will do the trick.
Annotation 2020-08-06 162313.png (29.2 KB)
I don't think that's what the dependents function does.
This function returns a list of nodes referencing the given node.
https://bitbucket.org/jcdeblok/jdb_houdinitoolkit/src/master/python_panels/ [bitbucket.org]
Check my ‘visibility manager’ panel. It has some buttons to select the whole tree a node belongs to, or all below/above a node etc. There are a few python function in the source that are easy to rip out.
More code, less clicks.
Thanks Jonathan, I will have a look.
In the meantime, I think I managed to get what I needed by writing a recursive function that inspects the references of a given list of nodes. The function find the references of each node, then look at their ancestors for new references, etc.
I don't think it's necessarily future proof, and I'll keep testing it further, but for now I think I got what I needed.
Please let me know if you guys feel like there is something wrong with what I'm doing.
### RETURNS REFERENCES FROM A GIVEN NODE ###
### Ignores the references inside a hda, as they are considered self contained ###
def getReferences(node):
    references = []
    if isNodeHDA(node):
        references = list(node.references(include_children=False))
        ### Removes children if referenced in the hda ###
        for reference in references:
            if isNodeChildOf(reference,node):
                references.remove(reference)
    else:
        references = node.references(include_children=True)
    references = list(set(references))
    ### Removes the node if it references itself ###
    if node in references:
        references.remove(node)
    return references
### RETURNS ALL DEPENDENCIES FOR A GIVEN NODE
def getAllDependencies(nodes, level=0, maxdepth=10):
    dependencies = []
    if level == maxdepth:
        return dependencies
    for node in nodes:
        references = getReferences(node)
        ## for each reference, get ancestors
            ancestors = reference.inputAncestors(include_ref_inputs=True,only_used_inputs=False)
            newDependencies = getAllDependencies(ancestors,level+1,maxdepth)
            newDependencies.append(reference)
            for dependency in newDependencies:
                if dependency not in dependencies:
                    dependencies.append(dependency)
    result = []
    for dependency in dependencies:
        if dependency not in nodes:
            result.append(dependency)
    return result
Edited by julien-b - 2020年8月6日 18:06:10
Hey julien-b,
I have stumbled across the same problem today and managed to solve it with a hscript command within python
https://www.sidefx.com/docs/houdini/commands/opdepend.html [www.sidefx.com]
so
hou.hscript("opdepend -d -e " + node.path())
should give you a list of dependency nodes.
cheers
Edited by Pirminus - 2024年9月26日 02:08:48
