Hi all,
While watching this LA Users Group presentation on Solaris: https://www.youtube.com/watch?v=6EDo6XkJk1g [www.youtube.com] , I noticed that Yuqing was able to just have a selection in his scene graph and drop down a Prune node which automatically filled the Primitive Pattern param.
Is this a custom hotkey or are there specific Solaris/lops keyboard shortcuts? I couldn't find a page that showed them. I find myself constantly having to fill similar params in other lop nodes and would be great if it just took my selection into account!
Scene Graph Tree shortcut
4688 3 1-
- Aylwin
- joakim
- 42 posts
- Aylwin
Ah yes, that's right, if I do it in the viewer it does try to populate it. I guess it doesn't work with every lop node with a primitive param though – i.e. Assign Material, Sop Modify doesn't pick it up. But thanks for this.
I will add though that Katana's ‘Add Scene Graph Selection / Append Scene Graph Selection /Remove Scene Graph Selection’ options in its parameters I think would be handy for these.
Edited by Aylwin - 2020年9月15日 16:58:06
- yelparesix
The Scene Graph shows all the nodes of a scene, organized in a tree structure. Imported files are highlighted in green. The root node is at the top of the structure and is a parent to all other nodes in the scene. The root node is a group node and cannot be deleted, renamed, or otherwise. forpc [forpc.onl] jiofilocalhtml.rum [jiofilocalhtml.run]
Edited by yelparesix - 2021年6月16日 21:18:21
