Poly-reduce with holes
1845 3 0- MathieuLeclaire
- 79 posts
I have a problem I'm not sure how to get around. I'm sure one of you guys will have a simple and elegant solution to this…
I need to poly-reduce some assets and the poly-reduce sop works very well in most situations, but here is a situation that causes me a lot headaches :
Sometimes, my high-resolution meshes ends up with little holes/missing polygons in them like this:
…it doesn't really matter for us when we render the high-res mesh since we never see these holes. They are occluded and super small.
But when we poly-reduce this mesh, these small holes become big holes like this:
…which now becomes a big problem.
How can I make sure my poly-reduce operation ignores small holes like this and treats the surface like a fully closed surface?
I though of using a polycap, but that closes the bottom surface as well and creates a weird shape in the end. I don't want that bottom to be capped, but I do need these small holes to be closed so my poly-reduce gives me clean results.
In this particular case, I could go and close those holes up by hand, but I have thousands of meshes to process, some with thousands of these small holes. So I'm looking for an automatic process that can close these small holes so that my poly-reduce operations can give me clean results.
Any suggestions?
Any suggestions?
Edited by MathieuLeclaire - 2020年11月3日 18:35:18
- MathieuLeclaire
- 79 posts
I just figured out a solution…
I'm measuring the throughout area of the mesh, then cap it. Then I measure the area per element. I divide the per element to the throughout area and if the ratio is bigger then a threshold, then it's the large bottom cap and I delete that polygon.
I'm not sure if it's the best solution, but it works. I'm open to other suggestions if there's an easier one.
Edited by MathieuLeclaire - 2020年11月3日 18:46:51
- vusta
- 555 posts
- vusta
- 555 posts
