Dear Experts,
I have a foreach by number loop in which I'd like to set the number of iterations to the value of a previously calculated attribute "@loopIter".
This attribute is visible in the geometry spreadsheet on the foreach_begin node and subsequent nodes in the loop, except for the foreach_end node, which is where I need it to give its value to the "Iterations" parameter. When I right click on the Iterations parameter and use the Reference menu option, I can sometimes see this attribute as being visible as a point attribute. Sometimes it is not listed, and I don't know what influences its visibility. When it is listed, though, and I select it, it gets a value of 0 rather than the correct value, so I guess it's not really there.
Should it be? If so, what am I doing wrong? Am I not approaching this problem correctly?
Thanks so much,
Mary
Trouble accessing local attributes in foreach loop
2179 6 2- mgbaker
- 73 posts
- vusta
- 555 posts
a bit convoluted trying to guess your aim so i could be on the wrong track....sue me.
just go into the control and drag around Target. Naturally, you can adjust Iter Distance too.
(just doublecheck if you need to + 1 in the points in the line creation ie. if you want a line to have 4 divisions, then it has 5 points)
Edited by vusta - 2021年5月29日 22:27:01
- mgbaker
- 73 posts
Thanks, vusta. I guess that is a different way to approach it -- copy the grid to each place first, then iterate across the grids doing what my null ("do_some_things") placeholder represents. I'll give that a shot.
I'm still curious, though, if anyone knows how to get the access to local attributes to work in the foreach_end parameter!
Thanks again,
Mary
Thanks again,
Mary
- Konstantin Magnus
- 670 posts
Hi Mary,
I think you would rather set the number of iterations to a detail attribute. Then access its value using the corresponding expression:
detail('../volume_size', 'loop_iterations', 0)
- mgbaker
- 73 posts
Thanks, Konstantin -- indeed in VEX that is what I would usually do. But if I were to try to make use of the foreach SOP -- how do I access that attribute in the foreach_end SOP Iterations parameter to set the iteration count? The attribute doesn't seem to be available whether it's a point attribute, detail attribute, or primitive attribute...
Thanks again,
Mary
Thanks again,
Mary
- vusta
- 555 posts
well if you put
in the Iterations at the end, you'll get 4
change your Distance in control to 0.25 and you'll get 8 iterations
(probably a bit confusing when you say local attributes tho, the loopIter are attributes that are readily widely avail, not just temporary local to some wrangle)
point(0,0,"loopIter",0)
Edited by vusta - 2021年5月30日 17:34:51
- daverosesumo
- 17 posts
