Pick a different edge to bridge a hole?
   1014   4   1
Assume a Font SOP creating a “4”. There are a pair of edges that join the outside of the “4” to the hole in the middle. Unfortunately, those edges are in the way where I need to do some tweaking, so I’d like to pick a different pair of points to bridge the hole. Unfortunately, I’m really drawing a blank at the moment. Any thoughts?
Thanks in advance,
Tim
clip...(keep all prims) but it simply moves your problem somewhere else
hey, i'm not a miracle worker!!
Edited by vusta - 2021年6月24日 02:08:58
At least one edge is needed to preserve the hole's information. You could try using Remesh -> Labs Quadrangulate -> Dissolve the edge you don't want.
you can also use Hole SOP to un-bridge the 4 into 2 curves
then process the 2 closed curves separately and use Hole SOP to bridge them afterwards
Thanks so much to you both for your suggestions - a combination of Clip (produces two bridges) and Dissolve (to get rid of one of them) worked like a charm.
Tim
