Can a pre-frame script edit the render settings?
   1872   2   0
In the same vein as https://www.sidefx.com/forum/topic/81229 [www.sidefx.com]
I have a preframe script that does a frame substitution on an attribute value but it's not being saved after the script is run.
Part of the USD file being rendered:
custom string ri:samplefilter0:name = "PxrCryptomatte"
custom string ri:samplefilter0:PxrCryptomatte:filename = "/path/to/render/dir/cryptomatte/renderproduct.cryptomatte.$F.exr"
I'm attempting to replace $F with the current frame from hou.frame() but the cryptomatte exr is still being written out with $F in it instead of the actual frame number.
I've confirmed the attribute value is being set on the stage by getting the attribute again and printing it.
Any help please?
Michael
Related question on why I'm running the preframe script: https://www.sidefx.com/forum/topic/82522/ [www.sidefx.com]
Yes, I believe it can.
