Turn Wedge Index into a sequence
   1556   2   0
Hi all,
I'm trying to turn all my wedge iterations into a sequence. Here's my exemple to explain :
I have 72 wedgeindex (iterations) if I want to cache them using a rop geo it means that it will load my scene 72 times.
What I'm trying to do is to create a sequence with those wedgeindex (wedgeindex1 appear frame1, wedgeindex2 appear frame2 etc...).
This would give me the oppertunity to load my scene only once and cache them like a simulation by ticking "All frames in One Batch".
The quickest way to do that is to use an Attribute Create after the Wedge, which can set the work item frame and add a range attribute. Set the Frame field on the attribute create to @wedgeindex, and create a range attribute with 3 components set to 1, @wedgetotal and 1:
Screenshot from 2022-03-14 13-50-12.png (24.0 KB)
Thank you very much that's exactly what I was looking for
