Vellum cloth droop on imported geo
   3060   3   1
Hello, imported geo for cloth sim droop too low even after I've pushed up stiffness values.
Any help please
オンライン
if it's due to stretching they you need ti increase constraint iterations/substeps
if however you are not experiencing stretching, just natural settling of your loose cloth under gravity, then it really depends on what you expect based on your particular case
- you can decrease restlength to force it to shrink a little
- increase bend stiffless to force it to hold the initial shape a bit more
- enforce with more constraints
- if you are starting with already settled geo from other sim you may want to override rest shape with original model or flat template, whatever is more natural to the nature of your sim
Edited by tamte - 2022年3月17日 04:48:41
CG Supervisor
Framestore, NY
Thank you Tomas! I will apply this knowledge and provide feedback.
A balance between substeps and bend stiffness did it for me.
In this case substeps of 2 and bend stiffness of 1 x 0.1 worked perfectly
