VirtuCamera plugin: Virtual camera for Houdini (Py3) and iOS
   19382   22   4
This is unofficial HDA bridge for VirtuCamera iOS app (https://virtucamera.com/)
Use it to connect and record camera movement from iOS devices and send the data to cameras in Houdini
Install HDA and libraries:
Unzip VirtuCameraHoudini-2.1.1.zip archive to any folder:
Copy 'virtucamera' and 'packages' folders to houdini18.5 user preference folder (ex. C:\Users\<user_name>\Documents\houdini18.5)
Run Houdini Python 3 version (developed and tested in Houdini Indie 18.5.582 - Python 3)
Import HDA in Houdini
(File -> Import -> Houdini digital -> Select VirtuCameraHoudini-2.1.1\otls\virtucamera.2.1.1.hdalc -> Install)
How to use:
0. Create new obj camera at scene
1. Create virtucamera node at obj context (Tab - VirtuCamera)
2. Press Open Capture Window:
Attention: Do not move Capture Window manually by mouse. Use Window position and size parameters. Change those parameters and press Open Capture Window button again to reopen window in new position and size.
Explanation: It's required because current implementation uses Screenshot method to capture video from your pc screen and send it to mobile device. Houdini need to know where Capture Window on screen to send this data to iOS device.
3. Press Run Server button
4. Open QR code or skip this step and use your_pc_ip_address:port later.
5. Install VirtuCamera app on you iOS mobile device (Tested with iPhone 11): https://apps.apple.com/us/app/virtucamera-unlimited/id1461676842 [apps.apple.com]
6. Run the VirtuCamera app
7. Connect to pc by pressing Scan QR code or connect manually by your_pc_ip_address:port
8. Choose your camera (ex. /obj/cam1)
9. Tap on black screen with eye icon to see video stream from your pc.
10. Press chain button in right top corner to calibrate mobile device and send transformation data to Houdini.
11. Look around until calibration done. Now you should see that your mobile device movements are sending to camera in Houdini.
12. Press record movement button (pure red) to start recording.
13. When the recording will be done wait a minute for plugin to put the data as keyframes on your camera.
Regarding development:
Made by using open-source API - PyVirtuCamera: https://github.com/shycats [github.com]
Feel free to modify HDA and share changes at the topic
It's required to import PyVirtuCamera python 3 libraries in Houdini to use a server functionality.
This is the main reason you need to run Houdini python 3 version.
https://github.com/shycats/PyVirtuCamera/releases [github.com]
I've already downloaded and put PyVirtuCamera-cp37-windows-x64-v2.1.1.zip to the plugins archive.
Questions for community:
1. Are there any ways to optimize python keyframes set process?
def set_camera_transform_keys(self, vcserver, camera_name, keyframes, transform_matrix_values):
""" Must set keyframes on the transform of the specified camera.
The frame numbers are provided as a tuple of floats and
the transform matrixes are provided as a tuple of tuples of 16 floats
with 4x4 transform matrixes, with a matrix for every keyframe.
The first element of the 'keyframes' tuple corresponds to the first
element of the 'transform_matrix_values' tuple, the second to the second,
and so on.
* The up axis is Y+
* The order is:
(rxx, rxy, rxz, 0,
ryx, ryy, ryz, 0,
rzx, rzy, rzz, 0,
tx, ty, tz, 1)
Being 'r' rotation and 't' translation,
Is your responsability to rotate or transpose the matrixes if needed,
most 3D softwares offer fast APIs to do so.
Parameters
vcserver : virtucamera.VCServer object
Instance of virtucamera.VCServer calling this method.
camera_name : str
Name of the camera to set the keyframes to.
keyframes : tuple of floats
Frame numbers to create the keyframes on.
transform_matrix_values : tuple of tuples of 16 floats
transformation matrixes to be set as keyframes on the camera 'camera_name'
camera_node = hou.node(camera_name) #Get camera node
for x in range(len(keyframes)):
key = hou.Keyframe()
key.setFrame(keyframes[x])
matrix = hou.Matrix4(transform_matrix_values[x]) #Convert tuple to matrix4 format
translation = matrix.extractTranslates('srt')
rotation = matrix.extractRotates('srt')
key.setValue(translation[0])
camera_node.parm('tx').setKeyframe(key)
key.setValue(translation[1])
camera_node.parm('ty').setKeyframe(key)
key.setValue(translation[2])
camera_node.parm('tz').setKeyframe(key)
key.setValue(rotation[0])
camera_node.parm('rx').setKeyframe(key)
key.setValue(rotation[1])
camera_node.parm('ry').setKeyframe(key)
key.setValue(rotation[2])
camera_node.parm('rz').setKeyframe(key)
2. Are there any ways to capture pixel buffer from scene viewer? I would like to know, because screenshot capturing is slow and not cool, but it works
Edited by FaitelTech - 2021年6月4日 02:00:03
VirtuCameraHoudini-2.1.1.zip (11.7 MB)
Hi Faitel, thanks for this fantastic addon.
I have this error running on Houdini
Let me know if there is anything I can help. Thanksss
VirtuCamera: QR Code generated in temp folder
VirtuCamera: Houdini plug-in version 2.1.1 | Server version 2.1.1
VirtuCamera: Accepted connection from: 192.168.2.36:54235
VirtuCamera: Client connected
VirtuCamera: Camera has changed to /obj/cam1
Exception in thread Thread-6:
File "C:\PROGRA~1\SIDEEF~1\HOUDIN~1.596\python37\lib\threading.py", line 926, in _bootstrap_inner
self.run()
File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.596/houdini/python3.7libs\hou.py", line 96303, in __threadRun
self.__run()
File "C:\PROGRA~1\SIDEEF~1\HOUDIN~1.596\python37\lib\threading.py", line 870, in run
self._target(*self._args, **self._kwargs)
File "vc_core.pyx", line 2289, in virtucamera.vc_core.VCServer._handle_tcp_socket
File "vc_core.pyx", line 2144, in virtucamera.vc_core.VCServer._proccess_command
File "vc_core.pyx", line 1336, in virtucamera.vc_core.VCServer._async_callback
File "vc_core.pyx", line 1340, in virtucamera.vc_core.VCServer._async_callback
File "vc_core.pyx", line 1953, in virtucamera.vc_core.VCServer._send_scene_status
File "Object/virtucamera, PythonModule", line 297, in get_camera_focal_length
AttributeError: 'NoneType' object has no attribute 'eval'
Poly Cruncher @ Naughty Dog.
Hi Santi, I'm sorry to hear that you got an error.
Plugin failed to find 'focal' parameter on your camera object, I don't know why exactly.
I've made the quick test (attached video and hip file) in Houdini 18.5.596 Py3 version, and the plugin still works for me.
Please try again and attach some screenshots or video if possible.
Edited by FaitelTech - 2021年6月24日 08:00:03
virtucamera_test.hiplc (908.6 KB)
virtucamera2021-06-24 16-20-14-1.m4v (6.2 MB)
Thanks Faitel. I got it working now.
オンライン
Works so well, incredibly smooth compared to using in Maya.
Thanks for creating and sharing!
Will this work on the houdini FX version?
Having connection problems
I don't have access to Houdini FX version, but it still works with Houdini 19.0.589 Py3 Indie.
This is incredible! Working great for me so far. Just curious if there's a way to hear audio playback on the timeline while recording. Audio works during regular playback but not during recording initiated from the app. Thanks so much for your effort on this!
aew928
Do you run on the "Indie" version?
unhrt
aew928
Yes. Using indie.
aew928
I've added audio playback support. That's not a perfect solution because of VirtuCamera's manual frame by frame playback mechanic, but better than nothing.
VirtuCamera plugin: Virtual camera for Houdini - Update 2.1.2
  1. PyVirtuCamera Library is updated to version 2.1.2 [GitHub [github.com]]
  2. Added support for scrubbing and playback audio files
Don't forget to remove VirtuCamera folder and otls/virtucamera-2.1.1.hda file from previous version and replace with new ones.
I'll upload demo video as soon as possible.
Tested on Windows 10, Houdini 19.0.622, iPhone 11.
Edited by FaitelTech - 2022年5月18日 20:57:51
VirtuCameraHoudini-2.1.2.zip (13.9 MB)
Faitel
aew928
You absolute beast. Its more than enough to pick up on basic audio queues for timing purposes. Fantastic job!
This is super cool , great job! thanks for sharing.
does it stream translation as well, like getting xforms from some AR type of camera ?
btw, regarding your question (1), use parm.setKeyframes() instead, and pass in a Keyframe() array, you'll get faster times than adding keyframes at every loop iteration, according to the docs. (see screenshot attached)
So maybe you could find a way to store all transforms during stream and set keyframes at a later stage ? (you'l need to have a frame range defined of course, as to know when its time to gather xforms and bake)
Edited by fabriciochamon - 2022年6月13日 19:55:26
fabriciochamon
Thank you for the tip, Fabricio! I'll test it. I'm also thinking of shifting from recording in device to recording in chops as alternative mode because I see that there are a lot of other ways to utilize device xforms and maybe it isn't smart to lock everything just on python and camera. So, I am actively discovering CHOPs at the moment.
PS: Thanks for your videos
When I downloaded and extracted the zip for v2.1.2 for windows, I only see the "virtucamera" folder. I don't see "otls" or "packages"
I also tried downloading v2.1.1 and the extract included all 3 files. However, I got this error.
File "Object/virtucamera/create_capture_window", line 1, in <module>
File "C:\PROGRA~1/SIDEEF~1/HOUDIN~1.303/houdini/python3.9libs\hou.py", line 50953, in __getattr__
return _hou.HDAModule___getattr__(self, name)
AttributeError: 'module' object has no attribute 'VirtuCameraHoudini'
Windows
Houdini 19.5
iPhone
2022-08-16 13_16_12-virtucamera.png (17.6 KB)
VirtuCamera plugin: Virtual camera for Houdini - Update 2.1.3
Moved from Python 3.7 to 3.9 version, now compatible with Houdini 19.5
How to install:
1. Download and extract the attached archive.
2. Copy (otls, virtucamera, packages) folders from setup folder to Houdini19.5 preference folder.
3. Run VirtuCameraExample.hiplc from example folder (optional)
VirtuCameraHoudini-2.1.3-py39.zip (13.8 MB)
I can't get it to work im getting this error:
File "Object/virtucamera::1.2/create_capture_window", line 1, in <module>
File "/Applications/Houdini/Houdini19.5.330/Frameworks/Houdini.framework/Versions/19.5/Resources/houdini/python3.9libs/hou.py", line 50891, in __getattr__
VirtuCamera plugin: Virtual camera for Houdini - Update 2.1.3 - Small Bug Fix
Minor fix for variable path in virtucamera.json package file.
Tested on Windows 10, Houdini 19.5.344, Iphone 11.
Edited by FaitelTech - 2022年8月20日 03:58:39
DirtyVibeMedia
DirtyVibeMedia
That means that virtucamera HDA can't find virtucamera folder in Houdini preference folder
Check that:
1) Documents\houdini19.5\virtucamera\python3.9libs folder exist
2) Documents\houdini19.5\packages\virtucamera.json file exist
3) You're running it on Windows machine
4) You're using python 3.9 Houdini build
any chance we can get this for Mac? would be super sick! thank you in advance
