Hiya
I'm looking to have a python script go into my HDA and insert lines of code within the Scripts -> PythonModule section. Is it possible to access this via python? To answer the "why would you even want to do this?" questions, i'm trying to automate a larger more complicated process which requires code within the HDA to be present.
I've been looking at hou.HDADefinition as well as hou.hda which came close as you're able to set callbacks but that's been the closest i've seen thus far.
python - script to edit python module within HDA
1584 1 0-
- wjm
- 39 posts
- wjm
- 39 posts
took a day and a half to find this but here's the answer for others looking
import hou node = hou.selectedNodes()[0] #get node nodeTypeData= node.type().definition().sections()#dict of available info from the hda sections. pycode = node.type().definition().sections()["PythonModule"].contents() #this gets the contents on the python module node.type().definition().addSection("PythonModule","Test string goes here")#overwrite the python module here. you can use a file read in place of the string.
Edited by wjm - 2022年7月21日 08:47:09
