In my custom HDAs, I often need to execute some functions every time the incoming geometry changes.
So far I'm using a Python Sop inside the HDA at the beginning of the network, but that's not ideal for different reasons.
In the list of event handlers I expected to find something like "On Incoming Geometry Changed" but there's none.
What's your setup in this scenario?
no "On Incoming Geometry Changed" event handler for HDAs?
2060 5 2-
- Andr
- 899 posts
- N-G
- 214 posts
- Andr
- 899 posts
- 9432 posts
- オンライン
- Andr
- 899 posts
- N-G
- 214 posts
tamte
To optimize your calls consider using Cache If SOP which can detect the geometry changes and trigger cook only when relevant
Dear Tomas,
Can Cache If SOP detect if an animated parameter doesn't change on each frame even though it may contain expressions like
floor($F * 0.1)for instance?Based on what I experienced so far seems it can't understand it and recooking happens every frame instead of every 10 frames!
Is there any trick involved?
