Houdini normal node issue.
2388 12 0- xavierqdeidan
- 16 posts
- animatrix_
- 4528 posts
That looks like viewport redraw issue. You can try to recreate the viewport. Restart Houdini, etc.
Also play with point, vertex normals, that could force reupdate.
- xavierqdeidan
- 16 posts
- CYTE
- 682 posts
- xavierqdeidan
- 16 posts
- Xue_Yue
- 56 posts
When these spikes appear after you apply a normal node, then it is a viewport issue (because the normal node won't displace your vertices).
My first suspect would be the driver for your graphics card. Is it the latest version? Or if you have the latest you could try the latest stable driver before that.
Edited by Xue_Yue - 2022年11月7日 03:06:00
- xavierqdeidan
- 16 posts
Xue_YueHello, I am on a MAC M1, could that be issue?.
- xavierqdeidan
- 16 posts
- CYTE
- 682 posts
- xavierqdeidan
- 16 posts
My apologies for all the inconveniences, OK I am attaching a new scene file, within the Geometry node there are two setups, the original from the tutorial and the one I had created "names also on each setup", up to the point where a add the Attribute VOP is added to separate the pieces from the fractured geometry my results are completely different in my setup there are no fragmente peces but distorted geometry, I had followed everything in detail, hopefully someone can help me.
Thanks in advance!.
Thanks in advance!.
- sepu
- 422 posts
- xavierqdeidan
- 16 posts
SEPU,
Exactly, at this point corrected. Now I am facing another issue, after the "Attribute VOP" there are two"Attribute Wrangle" nodes added, 1: "ADD_MYNEAR_ATTR2" located under the "Attribute Copy", and 2: "TRIGG_BY_DIST2" located after the null "EX_3D", I am using the same 'Radius parameters" In the wrangle nodes to control the color propagation in the inside faces of the geometry but after playing the values I can not get the same result as the tutorial, I had attached a new scene file and agree capture.
Anyone able to help, I appreciate the time taken to review the scene file.
Edited by xavierqdeidan - 2022年11月8日 10:36:19
- xavierqdeidan
- 16 posts
