Cannot set file path by python property script
   2888   4   0
I'm trying to set a file path property by referencing another property in the scene.
So I have PropertyA which has this file name:
"D:/vf/Library/Tech/Fusion/FusionComplexSetup/FramesFusion/a/vfx_complex_01a_12x11_F132.$F4.exr"
Then I have a File node that references this property.
But it never works. It says cannot find the file. I think that it is the $F4 that causes the problem.
If I link to the file manually it says exactly the same as the file above so the spelling is 100% correct.
Any idea what I can do to make it work?
Show us what the filenames look like. Does your file contain four zero padded digits?
Edited by Enivob - 2023年1月28日 08:39:15
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
Enivob
vfx_complex_01a_12x11_F132.0001.exr
I can make it read the file if I point only at the first so I have 0001.exr in the end. But the second I try to use $F4 then it stops working and it complains that the file cannot be found.
So just to iterate. If I would type this exact string in the file node then it works.
However if I have another node with a string/file property and I copy and paste relative, then it does NOT work.
This is in the img file node, that I try to load for compositing.
Andreas
It seems like no matter how I do it there is no way to have a File import of exr sequences with $F4 in the name. If I type it by hand it works, but it will never work if I set it by python or by a link to another property. The result will always be "cannot find file"
Could you please provide a simple file including the Python you have so we could take a closer look?
Edit: or try something like this and see if it helps in your case
hou.hscript('echo -n vfx_complex_01a_12x11_F132.$F4.exr')[0]
Edited by SWest - 2023年1月29日 10:28:14
