Hi all!
I am new to scripting and I am creating a tool with 2 buttons. When I run the script and click a button to create a cube, it is not created until I close the tool window.
I am researching and I believe the keyword I am looking for is “subprocess”. I want to be able to run the tool script I made as a subprocess and not have Houdini freeze until I close that window. The goal is to be able to go back and forth between the tool and Houdini without a problem.
I am using tkinter to create the GUI.
Does anyone know how to make his happen?
Thank you!!
Run Python Tool as Subprocess
1938 7 5- EstherRose
- jparker
- 293 posts
You might want the Python “threading” module, but not necessarily. I recall some discussion here:
https://forums.odforce.net/topic/21949-pythons-multiprocessing/?tab=comments#comment-130738 [forums.odforce.net]
- Alex Amos
- 28 posts
- toadstorm
- 359 posts
Honestly the best solution would be to skip tkinter entirely and use PySide2. It's way faster and it's built into Houdini. I realize it's a big package to learn but it's worth it considering how broadly applicable it is in VFX (Houdini, Maya, Nuke among others use Qt and include PyQt / PySide bindings).
- Lukas Chovanec
- 8 posts
- Alex Amos
- 28 posts
Hey all, thanks for the responses!
I was mostly looking into using customtkinter due to its out of the gate stylesheeting which makes the UI look nice, I'm guessing PySide2 is just as capable of doing styling?
Funny enough, I tried Paul's technique before finding that video, it seemed like it was working, but the data is still only pushed after closing the UI and not while the UI is open.
- toadstorm
- 359 posts
PySide / Qt is very capable of styling via QSS (basically Qt's custom implementation of CSS, with similar syntax), and QDialogs created as child dialogs of the main Houdini process will inherit Houdini's stylesheet by default. It's definitely a bit more boilerplate to deal with than tkinter but it's much more powerful and you don't have to deal with this threading business.
- Jonathan de Blok
- 254 posts
If you want to make UI panels that are native Houdini panels, use the windows->python panel editor.
Create a new interface and give it a name, also paste the code in there found at the bottom of this post.
and make to sure to add it to the pane tab menu:
You can then use the "+" on the panetab headers to add it to the UI:
Cubes are created instantly when you push the button and I've added some random styles to it for reference how to do that. Without styling it just looks like native houdini.
from PySide2 import QtCore, QtGui, QtWidgets
class MyPanel(QtWidgets.QWidget):
def __init__(self, paneTab):
QtWidgets.QWidget.__init__(self)
self.paneTab = paneTab
uiscale = hou.ui.globalScaleFactor() #this is here to compensate for difference UI scaling / dpi settings.
#global style sheet for entire panel
self.setStyleSheet("QPushButton {padding: "+str(20*uiscale)+"px "+str(40*uiscale)+"px; } ")
self.but_a = QtWidgets.QPushButton(self)
self.but_a.setText('Add Cube')
self.but_a.setStyleSheet("QPushButton {color: #ff0000}") #custom CSS for this button
self.but_a.move(QtCore.QPoint(10*uiscale,10*uiscale))
self.but_a.clicked.connect(self.but_a_pushed) # connect click handler
self.but_a.setText('Button B')
self.but_a.setStyleSheet("QPushButton {color: #00ff00}")
self.but_a.move(QtCore.QPoint(10*uiscale,75*uiscale))
def but_a_pushed(self):
#create a cube
c=hou.node("/obj").createNode("geo", "newCube")
c.createNode("box", "box")
print(f"Added box {c.path()}")
pass
def but_b_pushed(self):
print("Button B pushed")
pass
def onCreateInterface():
return MyPanel(kwargs['paneTab'])
Edited by Jonathan de Blok - 2023年3月13日 09:41:34
More code, less clicks.
