Error in Build a City With PDG Tutorial
   1000   0   0
I am going through the beginner tutorial for PDG found here:
https://www.sidefx.com/tutorials/foundations-build-a-city-with-pdg/ [www.sidefx.com]
...and when I get to step 4 (using a ROP Geometry Output TOP) all my tasks fail. When I right-click on the task to see work item info it shows this error:
/opt/hfs19.0.589/bin/hython-bin: can't open file '/tmp/houdini_temp/houdini_foundations_build_a_city_with_pdg/pdgtemp/19891/scripts/rop.py': [Errno 2] No such file or directory
I took a look at the pdgtemp directory and it had a data/ and logs/ subdirectory but no scripts/ subdirectory.
What could I be doing wrong? Note that I am building this setup from scratch, by following the video, and I am not using any of the pre-made hip files. Also, I have zero third-party packages or HDAs installed (not even Labs).
I tried changed the temp directory from houdinitemp to working dir, and I also tried starting Houdini as root to rule out permissions problems.
Edited by nicholasralabate - 2023年3月18日 00:20:26
