Vellum orient
   2286   4   2
Hi
Is tehre a way to keep initial orient on "attach to geomeetry" vellum cloth point. It seems that its only transform constraint and no rotation constraint. I would like it to behave the same way as vellum hair "pin to target" points.
in the mp4:
in blue cloth with attach to geo
in orange hair with pin tot target
stretch stiffness and bend stiffness are the same on both.
Or maybe a workaround?
THX
Edited by NAHASSIA - 2023年3月20日 15:27:15
vellum_orient.mp4 (43.0 KB)
orient_vellum.hiplc (495.5 KB)
You can dial in some of that by distributing mass across the gradient of the mesh. Calculate a 0-1 index from the relative bounding box of the source, in this case the x-axis. Use that index to drive a ramp where you can remap and rescale the final value. The net result is a little bit of falloff, and not a complete collapse.
ap_orient_vellum.hiplc (504.5 KB)
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
Very nice Enivob THX
only Hair can have true orient related constraint, even though you are not taking advantage of that in your file as you are pinning 2 root points instead of 1
however to get your left side working the way you may expect with 2 segments attached
- turn on Tangent Stiffness on /obj/VELL/vellumattach1
- increase your Bend Stiffness on /obj/VELL/vellumcloth1 to something like 1x10 or more
(or to 1x0.01 but also increase solver Substeps to 3)
Edited by tamte - 2023年3月20日 18:17:11
CG Supervisor
Framestore, NY
THX alot tamte I will try it.
