I Just cannot get this syntax right.
In either pointWrangle SOP or attributeWrangleSOP
To scale a float attribute (pscale) per point per time step.
@pscale == .9 ;
or
$pscale == .9 ;
No good
What am I getting wrong?
VEX code for scaling pscale per point per time step
3360 6 0-
- Dave_ah
- 436 posts
- Dave_ah
- 436 posts
- 9443 posts
Dave_ahso why wouldn't you try the same? (instead of trying == which is comparison of equality and not an assignment)
For Maya users equivalent MEL code would be
pscale *= .9 ;
@pscale *= 0.9;
assuming you run it in DOP environment, like Solver SOP or directly DOP net
Edited by tamte - 2023年7月3日 01:39:17
CG Supervisor
Framestore, NY
CG Supervisor
Framestore, NY
- Dave_ah
- 436 posts
tamtepscale *= .9 ;Dave_ahso why wouldn't you try the same? (instead of trying == which is comparison of equality and not an assignment)
pscale *= .9 ;@pscale *= 0.9;
Does not work in SOP level pointWrangle and attributeWrangle SOPs. Houdini generates syntax error and bypasses the SOP node.
- 9443 posts
Dave_ahyou forgot @ to bind to pscale attributetamtepscale *= .9 ;Dave_ahso why wouldn't you try the same? (instead of trying == which is comparison of equality and not an assignment)
here is an example in plain SOPs where this will be applied once to incoming value
and also inside of Solver SOP where it will be applied every timestep
CG Supervisor
Framestore, NY
CG Supervisor
Framestore, NY
- Dave_ah
- 436 posts
tamteDave_ahyou forgot @ to bind to pscale attributetamtepscale *= .9 ;Dave_ahso why wouldn't you try the same? (instead of trying == which is comparison of equality and not an assignment)
What is the difference between $pscale and @pscale in VEX? @pscale reads like Py.
Overall how does Houdini treat, in expression, @attribute vs. $attribute .
- BabaJ
- 2171 posts
Dave_ah
The @ symbol is typically used in a vex context to refer to the name that follows as an attribute.
The $ symbol is typically used in a context in which Hscript is being used.
That's the short and simple explanation although there is a bit more to it in certain cases.
For example, sometimes in a vex context you can use an Hscript expression(where $name is used) if enclosed within back ticks.
if(`$F > 5`) @pscale = 2; // Works in a wrangle code window but is less efficient than the next purely vex line. if(@Frame > 5) @pscale = 2;
