object merge using the output of another node
   1613   3   0
is it possible to use object merge, and point to a node that has multiple outputs and specify the number of the output you want to object_merge?
not sure if there is a general syntax to get it directly, but you can dive into groomfetch and see which node is passed to second output and object merge that one
so in your case:
../groomfetch1/output2
but as I mentioned, "output2" is the name of the node inside of groomfetch, not a generic getter to the specific output of the node
hair generate for example has second output node named "OUTPUT_SKIN" so it would be
../hairgen1/OUTPUT_SKIN
etc...
Edited by tamte - 2023年7月13日 11:46:51
CG Supervisor
Framestore, NY
I sent an RFE about this. It's currently not possible. There is no way to just refer to a specific output without an actual node reference. I can't find the RFE number unfortunately.
very nice form the UI! if you do / will show ALL the nodes inside and also that outputs
thought i would be needed to do a weird symbol or something like that!
