Difference between copying to points on polygons and not
   1267   3   0
オンライン
Hi!
Why do these two methods produce different orientations on the copied geo? As far as I can tell, there is no difference in the attributes present on the points when they are part of the circle and when they are not.
Directly from Circle:
Points Extracted:
Anson
Edited by AnsonSavage - 2023年7月13日 13:25:11
Screenshot 2023-07-13 102240.png (1.2 MB)
Screenshot 2023-07-13 102258.png (1.2 MB)
I'm guessing the circle has normals by default so it affects the copy-to-point. If you use the extractAllPoints, it probably removes the @N so you get a default orientation for all copies.
オンライン
olivierth
From what I can see in the geometry spreadsheet, there are no normals specified on the circle's points, vertices, or primitives... Are they implicitly created and read in the process of copying to points?
AnsonSavage
yes, many geometry operators use implicitly computed normals from polygons when they are not explicitly defined by an attribute
Edited by tamte - 2023年7月13日 14:40:34
CG Supervisor
Framestore, NY
