Sort scatter points on moving curve
1345 2 0-
- chuchvalec
- BabaJ
- 2172 posts
It's because at frame 53 and afterwards, you have points arcing downwards. You've defined your point order as the distance from location 0,-1, 0 - so those points are now nearer the other ones which are higher in y value.
You will have to devise an equation or some other method for sorting your point numbers - depending on what the entire range of your geometry will be doing.
Edited by BabaJ - 2023年12月6日 12:37:36
- animatrix_
- 5147 posts
You can freeze your animation using Timeshift SOP and then copy the point numbers by storing them as an attribute before the Timeshift.
