More than one layout nodes will cause problems
958 6 0- wanglifu
- 138 posts
If you have more than one layout nodes in your scene,and you drag assets from asset gallery,then you click between different layout nodes.Now you will find the assets disappear or just changed(I mean in the layout nodes,not the viewport).It's very annoying,this is a bug since 19.5,still not addresed in H20.
- mtucker
- 4441 posts
This is a known issue in the case where you are changing the asset gallery database (the choice of asset gallery database is currently global and affects all layout LOPs, and the working set can only refer to assets in the current asset gallery). There is an RFE to address this.
But if you are using the same asset gallery database for all the Layout LOPs, in my testing with the latest H20 builds, the individual working sets for each layout LOP are preserved. Please try the latest H20 build because an issue around this was recently fixed (though the issue was that the working set entries would "multiply" when switching from one Layout LOP to another).
- wanglifu
- 138 posts
mtucker
Nope,the asset in layout gallery still will disappear.
- mtucker
- 4441 posts
- wanglifu
- 138 posts
- wanglifu
- 138 posts
- rafeek
- 98 posts
