I read a texture in the "Attribute from Map" node,
When I attempt to save the modified texture map directly in Photoshop,
it prompts that the file cannot be saved because it is either in use or open in another application.
How can I make Houdini not exclusively occupy this file so that I can save it without any issues?
This way, I can modify the texture in Photoshop while observing the results in Houdini simultaneously.
Is the texture map locked?
1533 3 0-
- iJasonLee
- 4 posts
- 8213 posts
iJasonLee
You can't. On linux it doesn't lock the file, but if the file changes while Houdini is using it, it just crashes. I'd rather the file be locked than crash Houdini.
- iJasonLee
- 4 posts
- jerry7
- 681 posts
