Hello i accidentally replaced the defined sop/null with sesi_temporary::null
wich shows up above Sop/null wich is now in only to be found in the current Hip file.
This happend when i wanted to test what whould happen if i tried to add a scipt to a default node.
Does annyone know how to restore the default null ? as well as remove the sesi_temporary::Sop/null (in tge internally defined operators. (its shape and color changed icon stil the same and is listed in tab menu as null(digital asset)
