I am running a little test where I am trying to access the attributes of the next and previous points in a point cloud.
This might be a dumb problem since I've probably neglected something but why doesn't this work?
I am attaching the hip file.
Thank you in advance.
Edit: You can ignore the "distance" line. I forgot to remove it from the file as I am not using it.
Problem accessing attribute from a different point
317 3 0- TheoK
- 24 posts
- 8555 posts
- TheoK
- 24 posts
- animatrix_
- 4516 posts
If you are creating new attributes, you can't access these in the same wrangle node for other elements as they are not created yet.
So like tamte said, you have to use 2 wrangle nodes.
If you compile them, you would get the same performance as if they were one node.
