As title. I'd like to make my Vellum fluid kinda move more slowly in air, but not changing the gravity for other particles. I suppose it can be done by giving it some areodynamic drag.
Adding a POP Drag to give it wind seems to be close... but wind is a vector (as it should be), and I'd like an omnidirectional aerodynamic drag. Set POP Drag's air resistance without wind seems to do nothing.
How to set aerodynamic drag for Vellum fluid?
286 3 0- raincole
- 447 posts
- 8575 posts
raincoletry higher values maybe? It defilinely should apply drag to Vellum Fluid particles
on Vellum Solver SOP you can also use Forces/Built In Wind Drag, which is linked to internal POP Wind, but regardless ow what POP Wind or POP Drag you use you should see the effect
- raincole
- 447 posts
tamteraincoletry higher values maybe? It defilinely should apply drag to Vellum Fluid particles
Oh yeah it does make a difference. For some reason I assumed the range is 0~1...
Edited by raincole - 2024年4月19日 07:41:27
- Andrew Furlong
- 5 posts
